How does shipping work?
Through the Partner Portal, every order will automatically receive a prepaid shipping label from 3D Hubs to make shipping faster and easier.
When setting up your 3D Hubs account through the Partner Portal, you will be able to indicate which of the shipping providers you work with and which box sizes you have available.
setting - shipping - 3
Once an order has been inspected and is ready for shipment, you select the size of box that you will use for the order and then based on the weight of the parts calculated by 3D Hubs, you will receive a shipping label that should be attached to the box.
